My LG’s dryer button broken…terrible design. The button housing sitsin a flex plastic type square. The small plastic tabs holding the button broke. The switch behind the button is fine. I’ve tried to glue the button back into the housing but really want to buy replacement. I’ve looked and see some part places that sell entire control faceplate…$100 or so. I’m just looking for a replacement of the plastic button housing.
I also looked at several sites and it does not look like it is available as a separate part.
So you are stuck with your glue fix or some other jiggery pokery fix or buying the complete panel.
Hopefully someone else will jump in with better info.
Looks like the 2 button housings are the same so if you get a new panel I would pull the good one off the old panel.
Sounds like you may need it in the future.
PS: I am assuming it is out of warranty, if not see if they will replace it or at least give you a new panel at no charge or at a reduced price.
