LG not making Ice
Brand: LG
**Model Number:**lmxs30776s
Main Symptom: not making
What happens & when: the ice maker is not making ice. it used to work but now it doesn’t. It still sends water to the fill station, the stream is pretty decent,however the water supply to the ice maker does not engage. I can hear the valve in the back try to send water to the ice maker but no water comes out.
Error Code (if any): E 9F
Parts or tests already tried: replaced both valves, the one in the back,and the one in the door. Replaced icemaker.
The water pressure is good, the temp is good as well, I have powered off the refrigerator for 5 minutes, tried the ice maker on off switch, and tested the mechanism everything works. I have also removed the filter, replaced the tank and filter assembly.
The pipe is not clogged or frozen. I even disconnected the water pipe and tried to initiate a fill command, the back water valve tries to send water but the valve in the door doesn’t open
From everything you’ve done I’d say you are looking at the main control board AP5977757 having failed, or damaged wiring between that main control and the valve in the door.
https://www.appliancepartspros.com/lg-pcb-assembly-main-ebr78643401-ap5977757.html
