Brand: LG Model Number: LRYKC2606S/00 Main Symptom: Refrigerator not Cooling - Freezer works fine What happens & when:
Error Code (if any): NONE
Parts or tests already tried: LG Fan Grille Assembly (AEB76044923) LG Refrigerator Control Board(EBR32418503) , Humidity Sensor (EBR71326806) Door Seal/Hinges,
Check to ensure it is not a defrost issue (evaporator frozen up)…The ensure you have power to the evaporator fan motor…no power to the fan motor could be a control issue, a switch issue or a wiring issue.
