Brand: LG
Model Number: DLEX7800VE
Main Symptom: repaired broken connector
What happens & when: While cleaning dryer filter one of the connectors of the moisture sensor failed. I repair the broker connector and reconnected the two connectors and reassembled the dryer filter after cleaning. I want to make sure that I have not taken any safety risk by repairing connector versus replacing with LG moisture sensor connect assembly? Also is there a way to can confirm the moisture sensor circuit is working as expected? After reassembly, the LG dryer operate normally.
Error Code (if any): none
Parts or tests already tried: replaced OEM connector with a similar connector
Photos / video link: none
