I have an LG front loader that I need to change the spider on. The problem is that I can only get two of the six bolts out of the drum. The rest just spin around. I have looked but don’t see the bolts available online. If I can find the bolts, I would grind the heads off of the current ones, replace the lifters in the drum itself and finish the repairs. Any ideas?
Hi, Stephen.
In your case with only two good bolts holding the new spider I would recommend to replace the tub assembly:
Thank you,
Simon.
