LG LRMVS3006s/02 IF E error code
I have an LG LRMVS3006s/02 and I have an IF E error displayed on my front panel? The description I found was for an ice maker fan. What part number would I need? Thanks for your help
This issue will be a ice fan that is faulty and would need to be replaced. Here is a link to the part that you would need.
https://www.appliancepartspros.com/lg-grille-assembly-aeb76044903-ap7198421.html
The LG factory part number is AEB76044922. This part number has discontinued and replaced with part you linked in your reply. Thank you for your time.
