Brand:LG
Model Number:LMXS30776D 02
Main Symptom: Error Code E15
What happens & when: E15 message appears, I have followed the LG recommendations for a fix and replaced the ice maker, then the water valve and then the PCB board. The message continues to come back usually 1 to 2 hours after turning the power back on. I have read on forums of others having a similar issue and to resolve it they replaced the left side door. When you look up doors they are hard to find and the description does not say what all is included. I have taken the cap off and inspected the wire harness at the top of the door but not performed any ohm checks yet. Any thoughts or ideas would be greatly appreciated.
