LG ice dispenser
Brand: LG
Model Number: LFX25991ST /06
Main Symptom: ice dispenser not dispensing ice
What happens & when: No noise or light on front panel when trying to dispense ice. Ice maker still working fine. How do I know if the auger motor inside needs replacement or does the front panel with the dispenser switch need to be replaced? If it’s the front panel, which part would that be exactly?
This issue will likely be caused by a faulty display. Here is a link for the part you would need.
https://www.appliancepartspros.com/lg-cover-assembly-display-acq85430239-ap5782994.html
