LG Gas Range Oven Intermittingly Working
Brand: LG
Model Number: LGRL5825F/00
Main Symptom: Oven Will Not Warm Up to Desired Temperature
What happens & when: Anytime the Oven Turns On
Error Code (if any): None
Parts or tests already tried: None
The oven for my LG gas range will intermittingly not warm up when you start it up. I can see the ignitor turn on and emit a bright orange light from the opening in the bottom of my oven, but the gas valve does not seem to open as I don’t hear any gas noises or a click which usually triggers the gas to enter the oven. The ignitor will turn off after ~45 seconds and then turn back on again after about 1 minute. After a few cycles of the ignitor turning on/off, it will work normally. This also happened the previous time I used it, but the oven was at ~300 F when I turned it on to try and warm it up to 400F. The burners and the control panel on my range work with no issues. Once the oven starts, it will work with no issues.
In my opinion, I think I have a bad ignitor, but I wanted to see if there are other potential causes.
