LG gas dryer model DLG3501w te1 code
Brand: LG
Model Number: dlg3501w
Main Symptom:te1 code
What happens & when: shuts off after a few seconds
Error Code (if any):te1
Parts or tests already tried: changed the thermostat components
Photos / video link:I just want to make sure I am not getting the wrong part again. I am looking to purchase the EBR85130512 pcb. Is there another pcb that could also cause this error?
This would be the part for the main PCB, EBR85130512 Main Pcb Power Control Board Assembly | Genuine Lg OEM In Stock
Is there any other components that would trigger that code ? That I haven’t already changed
Either a bad control or a bad thermistor can trigger that error code. If the thermistor is out of range, it does not know the temperature of the dryer and will shut it down. It might be better to replace the thermister first. AGM30045804 High Limit Thermostat | Genuine Lg OEM In Stock, it is located on the back side of the blower housing
I’ve already changed three thermidor parts I had purchased locally. I ordered the control panel thinking it was complete w the electronics. So just want to make sure I am ordering the correct part. Thanks for confirming and I will place the order.
