LG Front Load Washer - Drum Spins Then Stops
Brand: LG
Model Number: WM2050CW
Main Symptom: Generation of LE Code
Washer Machine was running then stopped & generated the LE Code.
Selected the Drain Spin Cycle, the tub starts it sequence of back & forth., assuming to balance the load, then begins to spin to only then stop & comes up with Error Code LE. This will occur every time after turning off the washer & restart the drain spin cycle. A louder noise is present. Reviewing the possible issues on your website, I first found the issue maybe the Washer Rotor Position Sensor, then when searching again, it came up with it being the Washer Rotor assembly, based upon the above, I do not think it is the Stator. So my question is, which would be the your best guess, Position Sensor or Rotor Assembly?
Error Code (if any): LE
It would be recommended to check and make sure that the rotor does not have any cracks in the magnets. If this is good then it would most likely be the RPS sensor that is faulty.
