LG freezer not keeping temperature
Brand: LG
Model Number: LFC23760ST
Main Symptom: Freezer temperature too high
**What happens & when: Freezer temperature is around 25 degrees F, even when set to lowest temperature setting. Ice maker has stopped producing ice (perhaps due to insufficient temp?). Diagnostics from main board appear to be successful as far as I can tell - this board only has 2 test modes. Refrigerator seems to be proper temperature.
How likely is it that the freezer temperature sensor would be the issue? If not, what else?**
Does the compressor run non-stop and is there a heavy frost accumulation on the freezer evaporator?
