There is a rumbling in the drum when it is turning and is on. The drum seems to be loose in front and rear when moved up and down. If it needs Drum rollers…how do ya gain access to them, and how many is there? There appeared to be 4 on the parts diagram on the web site.
Here your parts
Replacement parts for LG DLE2514W Dryer | AppliancePartsPros.com
Yes there are 4.
Figuring out whether one or more are shot may or may not be difficult.
I would not order anything till you open it up and check things,
You may as well replace anything else that is worn while you have it apart.
Give the interior including the blower wheel a good cleaning.
Also a good time to check/clean your vent system.
The following should help
http://appliancedigest.com/index.php?/files/go/e7b3d186f83191af8a226dc26d9ad912/dle2515-lg-electric-dryer-repair-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
