Brand: LG
Model Number:DLE7300WE
Main Symptom: NO Heat on normal
What happens & when: No heat when on normal mode. will heat and dry fine with timed dry. Is this the moisture sensor that has failed?. The lent trap is clean the entire line was cleaned out for lent.
