When dishwasher is filling with water, I get an IE error code and cycle is stopped. I’ve replaced the Water Inlet Valve and the Guide Assembly and still get the error code. Where do I go from here? I have good water flow and wait for the temperature to get hot before starting the machine. All hoses are good and electrical connectors are tight. What is the Item A106 on the parts diagram? It is called a Filter Assembly but there is no water connection to this part on the machine. It has a circuit board on it on the dishwasher.
Hi.
Take the outer door panel off and check the wires stocked in the black insulation. That could be you answer.
The A106 item is the electrical noise filter. Has nothing to do with you problem.
