Keep getting a “be” error code. I used the correct detergent, tried the milk trick , leveled and turned off the power for 24 hours. I spoke to a rep and they said to run an empty load with just water. Still nothing- code keeps coming up just before drying cycle. How does machine sense over sudsing?. Any luck out there with this issue?
If the model number of your appliance could be provided, this will allow the most accurate information to be presented.
I have this same problem. I leveled it, rinsed it. Tried the milk trick and also unplugged it. How can I determine if I need a new bubble sensor or what the issue might be?
What is the model number of your dishwasher? Also, if you open the door after the dishwasher has been running for about a minute, do you notice a lot of suds inside?
