LG Clothes washer not draining
Brand:LG
Model Number: WT1101CW
Main Symptom:Not draining
What happens & when: I run a spin only cycle and the drum spins slowly, no water is drained, although pump seem to be on.
Hi swohnoutka,
Are you getting any fault codes?
It’s also possible that the drain pump is overheating, which could explain why it’s not draining. Another possibility is that the pump is clogged. Have you tried removing it to inspect it for any debris?
If you’ve already checked it and it’s clear, you may need to replace the drain pump
