Brand:LG
Model Number:Electric Single Oven
Main Symptom:Bake Element Fuses to Metal Chassis
Is it common for LG bake elements to fuse to the chassis when they fail?
I am just a DIY person and I have replaced the bake element in two similar LG electric single oven models. In one case, the bake element fused to the chassis, and I was able to remove about 3/4 of the element. In the other oven, I was not able to remove the element even with the assistance of someone else. We managed to place the new element on top of the old one. That was back in Dec 2024 and it has been working fine since then.
It does not help that these are hidden elements. If they were accessible from inside the oven cavity, it would not be so bad.
I have not seen this happen with other brands as far as I am aware.
Regards,
Gus
