Hello,
The drain hose on my Whirlpool washer sprung a leak. The original hose is just shy of 8’ long, the part number I’m finding “W10096921’’ has a description of being only 42” long.However on the 1" grid display if I count the one inch blocks I end up with the hose being the correct length of about 90".
Does anyone know if this part #W10096921 is the correct number for a hose that is 8’ long?
Thanks,cisko1624
About the best we can say here is to recommend you call APP and discuss the issue with them. They should be able to help.
Be sure and have your model number.
[quote=cisko1624;820210]Hello,
Thanks,cisko1624[/quote]
Hello,thank you for the reply,sidfink43.
I went to a local appliance parts store to check on part#W1009621, it is the correct part,nearly 90" long,has everthing but hose clamp included. All the websites have the right part number and picture but give the wrong description.
Thanks,cisko1624
