The ancient thing to do having to do with turning your table lamp all around the : off was going to be the toggle turn with your an outlet cable but a lot of information have is now all around the allowing an individual kitchen table lamps that can be dimmed do nothing more than on such basis as touching the base. The possibilities having to do with light in weight lights have also been expanded so that you have halogen,ugly – at this time LED light - weight lamps giving a multi function a big amount of your choice. led lighting led led downlights,recessed downlights,led ceiling light,led ceiling lights light tube led street lights,led street lighting,led street lamps,led street light led lights
Can you dim heat lamps? I have a 250W out in my brooding coop, and it’s a low roof. I can’t raise it anymore but it’s too warm for the chicks now. Just wondering if I can dim is so I don’t have to keep buying different wattages of bulbs
Wow!
Spam bot attack! Two on the same post. What’s up with that?
Read the first post on this page. It seems so familiar. ![]()
They are getting better at copy and paste.
