I have replaced both door gaskets and it is still leaking. Can anybody help me?![]()
make sure it is leveled, not tipping forwards or to one side. also, where is it leaking out of? the bottom of the door? how is the water level inside? is your float switch kicking the valve off?
The water is coming out of both sides of the bottom of the door. With the door skin off you can watch with a shop light and see the water coming out in waves every time the spray arm comes around. What is the float valve you are talking about? Thanks sooo much for you help. It does act like there is too much water in the tub.![]()
there is a little float normally on the front left or front right of the floor of the dishwasher. it raises up with the water in the tub, and when it gets high enough, it opens a switch, cutting off power to the valve. but this would not be your problem, as you said your spray arm was spinning. there is a little kit that comes with guards to put on the corners of your tub, let me research your model and see if they would work.
try looking at this article :
http://appliancejunk.com/forums/index.php?topic=1844.0
this may be your issue.
also here is a link to the corner guards i was referring to:
http://www.************************.com/PartDetail/Dishwasher-Door-Gasket/154701001/1465007
not sure what happened to that link!!! sorry
arrrgh. ok try this… look up part number 154701001. that may help you.
looking at your model online I see no parts listed for the little plastic deflectors. I have replaced several on various makes but your model don’t even show them installed or for sale. Are there any there now. Make sure your hinges are not bent in any way out of shape. I had this problem on kenmore units where users would overload door with weight and bend the hinges out of whack.
The hinges look fine . It only leaks out of the corners. Thanks:
