The AirInlet Assembly on the left side of of the dishwasher is leaking between the part and the steal dishwasher housing. The part is on back order until August 2011. Is there instructions anywhere explaining how to disassemble the part and replace the gasket?
Thanks for the help.
[quote=jammh7;406637]The AirInlet Assembly on the left side of of the dishwasher is leaking between the part and the steal dishwasher housing. The part is on back order until August 2011. Is there instructions anywhere explaining how to disassemble the part and replace the gasket?
Bill[/quote]
Bill,
I take for granted , you’re leak is on the outside of the tub, not the inside.
You’ll need to remove the unit from the cabinet first, and then,
[LEFT]"Removing the Water Inlet [FONT=Arial][SIZE=3]The water inlet is located on the left side of the dishwasher tub. 1. From the inside of the tub, use a small pair of Channel Locks™ and turn the inlet grille ¼ turn counterclockwise and remove the grille. [/LEFT] 2. The water inlet can now be separated from the dishwasher tub."
We dont’t know your plans, but , you should consider both parts,
