The water dispenser in the Freezer Door is dripping water. What part do I need to order to correct this problem?
THANKS
THANKS
First place I would check is the valve itself. Disconnect the tube from the valve to the water dispenser, and observe the valve to see if it is dripping. If it is, replace it. Tell us what you find.
AP3672839
