Leaking water dispenser on GE refrigerator
Is there a way to repair my leaking water dispenser?:confused:
Can you be more specific on the problem please?
The water dispenser constantly drips. It more than fills a glass overnight, causing water to overfill the tray under the dispenser and run down the front of the refrigerator. Otherwise ice maker and water dispenser both
work fine.
[quote=Gene;230346]Can you be more specific on the problem please?
Gene.[/quote]
Gene: I hope you can give me some info. My GE fridge water dispenser is dripping constantly. Otherwise ice maker & water dispenser is working fine. Thanks for any help you may be able to offer.
is there a way to repair my leaking water dispenser of Kenmore refrigerator Model # 253-51399104?
Janielynn,
Sorry for the delay.
Have you replaced the water filter recently?
If not, then the problem most likely is a bad water inlet valve on the back of the refrigerator (#800 on the diagram).
Here are the breakdown diagrams and Replacement parts for General Electric ESS25XGSAWW Refrigerator | AppliancePartsPros.com
Is it really leaking or it’s just dripping water?
