Leaking Washer
This is a Sears Electrolux Perfect Balance front loading washer. During the washing cycle I heard a swishing sound and at the end of the washing cycle there was a lot of water dripping in front of the appliance onto the floor.
Parts for Electrolux EIFLW55HIW0 Washer - AppliancePartsPros.com
You will have to open the unit up and find the leak.
Below is a link to a manual which should help.
Unclick the Our Download button then use the grey Download button.
Otherwise the site may install software on your computer that you do not want.
Download Electrolux Front Load Washer.pdf
Common leak locations at the front of the unit are the door seak and the tub boot.
