Leaking washer and won't drain
I just purchased a home with a washing machine that doesn’t work properly. When I turned it on, it started leaking. I stopped the machine mid cycle and this might (or might not, I’m not sure) be the reason why it isn’t draining. I’m hoping that someone can help me with these issues. Also, I doubt it’s related, but it might be worth mentioning that upon further inspection I found out that the heating element is broken. Keep in mind that I’m basically an idiot and have no idea what I’m doing… haha
Replacement parts for WHIRLPOOL KUDI01DLBS0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
First you have to find out where it is leaking from.
Remove the kick plate so you can see underneath.
A small mirror and a flashlight can be a big help here.
