Brand: Whirlpool
Model Number:wrt318fzdw09
Main Symptom: leaking
What happens & when: leaking into freezer
Brand: Whirlpool
Please provide more information. Where is the leak happening? Are you sure it is coming from the icemaker, or is the drain pan under the evaporator iced up? We love pictures!
Wanted to add that my ref refrigerator is not level it is leaning towards the back could this be part of the problem?
The level part could be an issue, but probably not. It would have to be wayyyyy out of level. Take the front plastic cover off the front of the icemaker; it pops off. This may sound weird, but smell the front part of the motor module; it should have a white, round dial. If it smells burnt, replace the icemaker. If it looks and smells ok, replace the water inlet valve. Make sure also that the fill tube is in the right position so that water is making it into the cup of the icemaker and not squirting out.
