Leaking garbage disposal
PRO333 IN SINK ERATOR has leak. On the bottom there are several screws. Water is slowly dripping through one of theses screws. I do no have a manual or diagram. Can this be repaired from the outside?
I put some weld around the leaking screw. Now it is leaking around electrical cord going in to the disposal. Not getting any answers, but it is like a journal of this leak.
Have you tried to contact the manufacturer?
