Brand: GE
Model Number: GCWN5050M0WS
Main Symptom: Leaking after fix
I replaced the mode shifter and shaft assembly using the video below (awesome walk through).
I got everything back together but when I run the washer now there is water coming from the bottom of the tub where the shaft comes out. Is it supposed to sit all the way down to the notch on part? As pictured below I have a gap. That doesn’t seem right but I can’t get the shaft to move since its screwed into the bracket with the pulley and stone on it.
That stepdown on the shaft should be flush against the washer. Just making sure here, you’ve referenced the video for assembly WH38X10017, can you confirm that is the part # that was ordered and received?
I received the correct part. So I took everything apart again and when I took the last bolt out of the motor housing the assembly fell into the right position (notch seated to drum). I think I over tightened those 4 bolts that are supposed to be tightened to 90 inch pounds. I dont have a torque wrench so I guessed. I think I was wrong. I am currently trying to find a torque wrench that will do the job properly. I will report back when I put it all back together again.
So still no dice. I cant get it to sit flush. I am missing something. Here is a video that shows the movement.
It’d be unlikely to be the shaft assembly out-of-the-box but possible. The other possibilities are the outer tub which has been updated to part # WH45X20473 and may have undergone a design change, or the bracket assembly WH17X10016 that the shaft assembly mounts to which has been discontinued and is no longer available for purchase. The manufacturer hasn’t released any notes on redesigns or anything like that on any of these parts, so I would contact our customer service team at 1-877-477-7278 to get that shaft assembly swapped out as a bad part before replacing the tub.
One other thought, could I try a washer(s) between the assembly and the bracket to close the gap so the stepdown sits flush?
I can’t suggest that as a repair but it may work. If it was me working on my own washer I would probably give that a try before looking at replacing anything else, but that’s only speaking for me personally.
Update, we have one of these in the shop and my colleague took it apart to check. There is supposed to be a gap between that washer and the stepdown on the shaft. With that being the case, I’d suspect an issue with the tub seal WH02X10383 which should have been included with the shaft assembly. It could be that it isn’t mating properly. Did you apply any liquid detergent or other substance to that seal to dampen it when you installed it? If not, the issue may be that the seal is dry and not making a good seal to the outer tub and tub bearing.
I did apply detergent when installing, maybe not enough? I noticed that when I took the machine apart the 2nd time the tub seal had shifted up and wasnt flush with the tub anymore which could explain the leak?
My washer/shim idea didn’t work, I saw your message after working on the machine all night. I really appreciate you looking into this. It leaked again however, I am going to take the machine apart again for a 3rd time tomorrow and I am guessing the tub seal shifted again. This machine is 15 years old, I am going to try one more time.
I reseated the tub seal with detergent again, its still leaking down the shaft of the assembly. I think its time for a new machine. I am at a loss.
