Leakin water from Bosch dishwasher
Brand:Bosch
Model Number:she43m05uc
Main Symptom:leaking from bottom of door
What happens & when:leaks from bottom of door when running cycle. Looks like door seals but my question is the insulation on the door is wet. Do if the lower door seal is leaking does that insulation get wet or is the soap dispenser leaking too?
The insulation can get wet from a leak at the bottom of the door. However, it would be worth inspecting the lower spray arm jets and under the lower door seal for any food residue or debris that might prevent proper operation. A clogged spray arm jet can cause the water to create excessive waves, and debris or residue under the lower door seal can stop a proper seal from forming, resulting in leaking.
