LE code
Machine fills with water, then LE code comes on. Have cleaned impeller then replaced virio motor. LE code still comes on. Any sugesstions.:frowning:
Hi.
If you already replaced the wash motor and checked all the connections - replace the PC board.
For the correct part number, please provide serial number.
Thank you.
Simon.
