Brand: Maytag
Model Number: LDE4914ACE
Main Symptom:
Photos / video :
Pictures 1 and 2 are of my dryer motor that you sent me. Pictures 3 and 4 are two possible wirings that you sent me. I have wired black, yellow and red in accordance with the diagrams. I have two blacks and two yellows which does not correspond to your diagrams, but I am making the assumption that this should be done - if not you can correct me.
I wired up the first time using the first diagram (picture 3.) I have a gray wire vs. a white wire and a baby blue vs dark blue wire as you can see from picture 2 - I installed the gray on the terminal behind the row and the baby blue on to terminal 1. Nothing happened.
I wired up the gray wire with a jumper to terminal 1 and took off the baby blue wire as in diagram 2. Again nothing happened.
I removed the gray wire from the terminal behind the row and hooked the baby blue and gray wire together on terminal one. the breakers tripped and I blew the fuse on the dryer with this arrangement.
I have since replaced the fuse. I have had the dryer door switch wired up in each scenario above so this apparently is not the problem.
I need to know what to do from here to make the dryer motor work.
