Latch problems with amana dishwasher
This is the second time that my d/w latch has broken. I am very frustrated with this and would not purchase another amana. Is this a common problem?
It is very hard to say why and how it happened.
What part of the door latch exactly broke?
Howdy,
We have the model ADW850EAS and YES, the door latch/start connection stopped working for us as well. Hubby took front panel off and saw some plastic (white) connection thing broken. We started putting a rolled up
newspaper between the door and the top of the dishwasher to some how make that electrical connection work. We did the newspaper trick BEFORE we took the front panel off. We took the panel off after the newspaper trick no longer worked. It just stopped working the other day and we had to order the entire Black Color Door Handle Latch Assembly. I think it is about 62$ plus shipping.
Specifically we have MFG # PADW850EAS2 (but I think anything in this line
has the same problem).
the plastic piece on the latch handle broke off. i bought a replacement and now am looking for instructions on how to replace. do i need to turn off the power to the dishwasher?
Yes, you do have to turn the power off prior to disassemble the control panel.
Thank you. It looks like I need to remove two screws with an allan wrench to replace the latch. Is that right?
I’m not sure if there are an allen head or torx head screws used.
I can’t get the door open so how do I take it off? I believe the torx screws are on the inside.
What are the make and model number of the dishwasher?
It is a 2004 Amana SofSound. I don’t know the model number because my tenants lost the manual and it is written…you got it, on the inside and I cannot open it. It has the handle that you push up from under to release the catch. Except it is just sitting in the door and puching it or moving it doesn’t seem to engage/disengage anything. It would be great if you have any ideas. Thank you so much for replying.
I believe the only way to unlock the door is to pull the dishwasher out of the cabinet for a few inches and remove the two screws on top of the dishwasher securing the door strike to the tub.
For the last couple of months our door has been sticking (or what I thought was sticking), but tonight it broke with a full load of clean dishes in it. This dishwasher is barely 3 years old. It was brand new with our renovated condo when we bought it in 2007. I am BEYOND frustrated - this feels like poor quality and after doing some research online it feels like a COMMON PROBLEM. Is this somehing relatively easy to fix? Sould we call Amana or someone else? Thanks.
I was surprised how easy it was. I got the part number from one of the repair websites. Bought it on line because none of the local guys had one. VERY important unplug the dishwasher…ask me how I know! Use torx driver to take inner panel off. I think the same screws released the door latch assembly. Pull the assembly out, remove the two connectors (this was the hardest part for me they were well connected), replace. EASY and only took about 15 minutes. Don’t pay to have this done.
