Latch broken;door will not close
The door of my Whirlpool dishwasher does not close; the handle feels floppy.If I push the door firmly and attempt to start the washer it will not start.Could it be just the latch/ bolt that’s broken here or is there some electrical issues involved? Thanks for your response!
You have to remove the inner door panel (the instructions are attached) and inspect the door latch.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU920PFGQ3 | AppliancePartsPros.com
DU800 - 900 Removing the inner door panel.pdf (47.6 KB)
