Attempting to wash with hot water. Washer fills with cold water only. Hot water hose is hot. Hot water and cold water valves are open.
The only way I know that the hot water hose can get hot is if hot water is flowing. But I don’t know where it is going.
If cold water is flowing when the temp selection switch is on hot then try changing out the temp selection switch.
If you need more input please post a full model number and let us know what happens with a new temp selection switch.
