L Hinds
This washer pumps the water out of the tub, but about half of the time it will not spin the water out of the clothes. It makes a sound like it is spinning but it is not. I have replaced the timer. What is wrong?
Try replacing the clutch, this site will tell you how to get to it. On the way in check the motor coupling which could also be the problem.
Clutch Replacement on Whirlpool and Kenmore Washers
most likely the drive coupler is broken.
