Brand: KitchenAid
Model Number: KUDS35FXSS8
Main Symptom: Replacement part issue
I am looking to replace the 3-layer insulation at the toe panel of my machine.
Originally, there were two parts in this assembly:
4 - W10385107 Insulation, Toe Panel Access Panel
18 - W10350437 Insulation,Three Layer
Both parts have apparently been replaced by a single part W10831329, which is a single, thin piece of insulation. This new piece is less than 1/4 of the thickness of the original assembly – it is not compatible. Please advise.
Original KitchenAid parts diagram: KitchenAid KUDS35FXSS8 Manual
