KUDC10IXBL1 No power
Brand: Kitchen-aid
Model Number: KUDC10IXBL1
Main Symptom: no power
I bought a house. The house came with a KUDC10IXBL1, so I don’t know much of this appliance’s history. It operated as expected for a few months. Then the blue LED behind the “Heat Dry” button burned out. A few weeks later the touch pad would take a few tries before any button would respond. Then the issue worsened to where I might have to let it sit for several hours before it would respond again. Then finally it died altogether.
I ordered a control board. When I actually went in to replace the part, I found the old control board in bad shape. The P4 connector was charred black and fused to the harness connector. Unplugging the harness from that connector was impossible so I had to cut the wires.
I also noticed that, at some point, the door latch wires had heated sufficiently to melt little tracks lines where they came in contact with the door’s insulative layer. Or that may have been due to residual heat emanating from the P4 connector. I’m not sure.
Because the harness to P4 was destroyed, and because the AppliancePartsPros site said a replacement was unavailable, I used some spare female spade connectors to remake the individual wire connections to the new control board.
After putting it all back together again, the first test cycle ran perfectly. When I tried to run the next cycle, the touch panel was unresponsive again. No new charring or melting was found on the replacement board. Just going by what the unaided eye can see, it looks fine. The thermal fuse tests good.
Does anyone have any idea where my troubleshooting should go next?
Based on the information provided, it sounds like the user interface and console assembly has a short in it. If you turn the power supply off for 5 minutes then turn it back on, does the interface operate? WPW10500176 Panel-Control (Blk) | Genuine Whirlpool OEM In Stock
No. I had the circuit breaker open while I was inspecting after this most recent failure - at least 20 minutes. No response when I restored power to it.
That would point to a user interface failure. A quick way to confirm is to turn off the power, disconnect the interface wire from the main control, then reassemble the door just enough so it can latch. Keep the door open, turn the breaker back on, and after about 7 seconds, close the door. If the drain pump kicks on, that means the main control is working properly, and the user interface is indeed the problem.
Followed those steps - confirmed, the user interface is indeed the problem. Thank you!
