KRMF706ESS04 Evaporator Freezing up
Brand: Kitchen Aid
Model Number:KRMF706ESS04
Main Symptom: Coils Freezing up
What happens & when: I had a weird noise coming from the freezer. The fan was rubbing on ice buildup on the evaporator coils. I manually defrosted and tested the defrost heater. Had 30 ohms. I can feel cold air movement in the freezer. But after a week, it freezes up again. Any guidance would be much appreciated
Ty
Error Code (if any): No error codes
Based on the model number and information the temperature and defrost sensor and the main control needs to be checked. Attached is the tech sheet for this model.
https://www.appliancepartspros.com/repair-help/refrigerator-repair-help
