Knobs just won't turn
A cleaning service cleaned our old stove and now none of the range tops knobs will turn…oven works fine, but can’t get the burner knobs to turn for anything..help???
Most likely they are improperly installed. Remove all knobs and carefully reinstall them. Make sure the valve steam is properly aligned with the central hole in the knob. If you need more specific instructions, post the complete model number.
