kithenaid washing machine is moving around laundry room on spin cycle
thuoght i could just even out the load but it seems to beunmounted or something it literally just starts spinning and gets going then just bangs around. any help would be great. Im hoping its something simple that i can fix
You can remove the front panel screws, tilt the panel back, remove the retaining clips both sides, unplug the lid switch socket and tilt off the outer cover. Carefully look at the skate board under the tub and see if it sits evenly on the frame.
