Kitchenaide KDTE254Ess3
Brand: kitchenaide
Model Number:KDTE254Ess3
Main Symptom: drip, leak,
What happens & when: start up
Error Code (if any):none
Parts or tests already tried: kick plate off, started cycle and when pump starts, after maybe a minute, water drips from the round hole in the bottom of the diverter motor. pulled DW out and noticed moisture inside that hole. trying to figure out if I need a diverter motor, a motor to pump seal, or a sump assembly. am I on the right track?
The water leak is going to be caused by the diverter seal in the sump. Unfortunately, it is only available as a part of the sump. However, a leak at that spot can potentially cause damage to the diverter motor since the leaking water can accumulate on the motor itself. If this happens, the diverter motor would need to be replaced as well. Here are links to each, as well as a link to the entire circulation pump and sump assembly for comparison.
Sump- WPW10455268 Dishwasher Sump Assembly | Genuine Whirlpool OEM In Stock
Diverter Motor- W10537869 Diverter Motor | Genuine Whirlpool OEM In Stock
Circulation Pump and Sump Assembly- W10902372 Pump And Motor Assembly | Genuine Whirlpool OEM In Stock
