KitchenAid won't start
Hi there,
Last night when I attempted to run my dishwasher I found that none of the LEDs on the control panel would light up. After reading online, it looks like my thermal fuse may need to be replaced.
  1. Could you please provide the part number I can order?
  2. If I access fuse, will I be able to tell visually that it has blown?
Many thanks,
Jeremy
Replacement parts for KUDS03FTSS3 models | AppliancePartsPros.com
Note that the SS0 actually has a parts diagrams the others do not.
The thermal fuse is a bi-metal AP4423189 (Item 3 in Section 2)
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Tech%20Sheet%20-%20W10130990.pdf
[COLOR=“RoyalBlue”]
  1. Could you please provide the part number I can order?[/COLOR]
    See above
[COLOR=“RoyalBlue”]2) If I access fuse, will I be able to tell visually that it has blown?[/COLOR]
No, the only way to tell is with a meter.
If unit seems totally dead then it is always a good practice to check that the unit is getting power. Sometimes even the wirenut connections in the terminal box can become bad over time.
Well I swapped in a new bi-metal fuse, but still nothing. There is power at both the fuse and the door switch. I’m wondering if it’s going to need a whole new control board? Is there an easy way to tell if the board needs to be replaced before I call a service man from Kitchenaid?
Thanks again,
jeremy
There is no easy way to check the board if it seems totally dead.
You said that there was power to the door switches , have you checked the switches to be sure they are OK and are being closed.
If you check for power at the board and it is OK then the board is probably toast.
