Kitchenaid Wont start. Panel lights work
All control panel buttons and lights appear to be working normally. Door locks fine. Nothing stuck under auto shutoff float.
I shut breaker off for 5 mins and attempted to restart.
Nothing happens after start button pressed, lit and door shut. No water runs.
Worked fine yesterday. No signs of anything breaking or running intermittently. Just DOA now.
Any suggestions? Tnx
Replacement parts for WHIRLPOOL KUDP01FLSS6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Check that the unit is getting power.
Check that the wire nut connections are OK.
Check the door switches.
A common problem is the thermal fuse Item 6 in Section 2.
If it is blown be sure to use the new wiring harness that is included with the fuse.
This does not totally eliminate that something else is blowing the fuse but often it is just the hook up of the fuse.
