Brand:Kitchenaid Model Number:KUDP02CRBS4 Main Symptom:grinding / straining noise when cycle starts What happens & when: Whenever i start the dishwasher cycle as the water start being pushed into the machine the straining sounds start as well. i guess it could also be described as grinding. I think I have a decent idea on what needs to be done - replace motor and pump, but trying getting a sanity check nonetheless. Uploading a recording of the sound with the post.
TIA.
Parts or tests already tried: i have already tried an empty cycle and same sound.
Growling/grinding that continues throughout the wash cycle
Access
Remove lower rack.
Remove lower spray arm.
Remove accumulator/filter cover.
Remove chopper cover (Torx screws).
Inspect the chopper blade and screen before condemning the circulation motor.
On this Whirlpool-built KitchenAid design, a piece of glass caught in the food chopper is one of the most common causes of a sudden loud grinding noise, especially if the unit was previously running quietly and still cleans reasonably well. If the chopper area is clear and the noise sounds like a continuous growl, the circulation motor becomes the primary suspect
Thanks. removed the impeller blade and screen and cleaned them. there was soft buildup around it and the spring - likely paper from labels forgotten but nothing else. i did notice the rubber seal was pretty worn out. I also removed the motor from the body and there is a lot of desposits / residue. see pic.
Replaced pump motor and filter assembly and seems to have helped. Not back to original quiet sounds that i was used to but definitely eliminated the grinding / growling sounds. i will take the win.
