have older kitchenaid washing machine will fill and wash then when ready for rinse cycle made a funny nosie then will not rinse and spin unless i turn time all the way around to rinse is this a timer problem?
Can you tell were the noise is coming from?
What happens if instead of turning the timer all the way around you simply open and close the lid? Does it start then?
opened and closed lid did not help not sure where noise came from wssnt on very long and then machine quit till i tuned control around again
opened and closed lid didnot start soon as it got ready to go to rinse cycle made real short nosie couldnt tell where it came from tried to move control over to get it to start had to turn all the way around to where it was then it started and finished wsh cycle fine
[quote=ApplianceJunk;637237]Can you tell were the noise is coming from?
What happens if instead of turning the timer all the way around you simply open and close the lid? Does it start then?[/quote]
[LEFT][COLOR=#000000]opened and closed lid didnot start soon as it got ready to go to rinse cycle made real short nosie couldnt tell where it came from tried to move control over to get it to start had to turn all the way around to where it was then it started and finished wsh cycle fine
Read more: http://forum.appliancepartspros.com/washer-repair/393005-kitchenaid-washing-machine.html#ixzz1hr0kVWzj
http://forum.appliancepartspros.com [/COLOR][/LEFT]
