KitchenAid washing machine timer removal
I bought a new timer for this but can’t get the cover off after unscrewing back. Can’t get the timer knob off.
How can I do this?
You have to open the console in order to access it. Use 3 first steps from the instructions attached to the reply.
The knob is screwed onto the timer shaft. You should be able to unscrew it while it’s pushed in.
How to remove the washer cabinet.pdf (43.7 KB)
