KitchenAid: top oven will not heat
I have a KEBS278SSS02 (kithchenAid double oven) that has stoped heating on the top oven. The bottom works. The numberic pannel works for the top, the lights come on, I can set the temperature, the fan works…all OK with the top BUT, when I push start. NOTHING! no heat, just keeps saying “preheating”. Heating element cold. The convection fan will run. Like I said, the bottom oven works fully.
Most likely the problem is a bad oven shutdown thermal cutoff (#28 on the diagram). It is located on the back of the oven and the oven has to be removed from the cabinet for repair.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KEBS278SSS02 27" BUILT-IN ELECTRIC DOUBLE OVEN THERMAL CONVECTION | AppliancePartsPros.com
:slight_smile: :smiley: Thank you for the $11.00 fix and a little elbow grease. FYI, the failure happened within 3 days of an long cycle oven cleaning. I don’t know if they are related.
You are welcome. I’m glad it’s up and running.
It is very likely that the oven got overheated during self clean.
