My front panel which dispenses Ice and Water stopped working. Even the light will not go on.I replaced the font cover assembly, and it still doesn’t work. What else could be the problem? Everything else works fine.
Check the wire harness under the freezer door.
Here are the break down diagrams for the Kitchen Aid refrigerator Model KSBS25FJBT00
Thanks Gene. I’ll give it try and let you know if it works.
