when setting temp on bake or convect bake, enter 350 degrees (for example), hit start, get “err” message and it drops temp to 260 degrees?
[QUOTE=jackclarkjr;813747]when setting temp on bake or convect bake, enter 350 degrees (for example), hit start, get “err” message and it drops temp to 260 degrees?[/QUOTE]
Jack, Check and make sure the control board has not been set for “Celsius” by accident. If that isn’t the issue, please re post and supply a proper model number of your wall oven, so we can investigate further.
model is KESC307BWH3
How do i check celcius?
found another thread with info about changing to F from C. that did the trick! Thanks!
[quote=jackclarkjr;813754]model is KESC307BWH3
How do i check celcius?[/quote]
Jack, “Open the oven door, then press and hold BROIL pad for 5 seconds.(You will know you are in Celsius when “F” disappears.) To switch back to Fahrenheit, press “Broil” pad again for 5 seconds(“F” will reappear.)”
260dgrs. C. is equal to 500dgrs. F. which is the top temperature range for a “Bake” cycle, and could create the ERR display code.
You’re Welcome !!
